Home > Maintenance & Modifications > Nugget Stuff Airbox |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
Excellent, this is top of my future mods list. 2007 110 TDCi Station Wagon XS
18th Aug 2020 3:05pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3616 |
Interested in your feedback Chris once you get a chance to give it a thorough test drive. |
18th Aug 2020 6:47pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Once it's sorted you can have a drive Col. Rgds. Chris |
18th Aug 2020 6:50pm |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 152 |
Remap, remap, remap
18th Aug 2020 10:20pm |
We spoke, you know it! Rgds. Chris |
18th Aug 2020 10:23pm |
Ok all done.
Gone slightly lightly off piste - the 'Provent' is aneBay copy. After lots of research it appears to me that the internet scaremongering has no foundation when used on a TDCi. The standard system on a Defender without any catch can arrangement is a 19mm hose that goes from the rocker cover to the airbox - end of. Using a 'Provent' simply adds a reservoir between the rocker cover and the airbox - it cannot be 'pressurised' in any way since 1) it is simply a reservoir in an 'open to atmosphere' hose, and, 2) the 'Provent' has a valve in the cap which prevents any overpressure in the first place. The vent has been run through the wheel arch liner with a quarter turn valve next to the brake hose. Will keep updating as use clocks up. So far, engine runs like it always did. Click image to enlarge Rgds. Chris |
22nd Aug 2020 8:46pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3014 |
Nice one. Presumably the intake is sealed all the way to the RAI.
Have you driven it in anger yet and if so what kpa showed on the Informer? WARNING. This post may contain sarcasm. |
22nd Aug 2020 9:00pm |
Yep, completely sealed from snorkel to airbox. Rgds.
Chris |
22nd Aug 2020 9:02pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16871 |
The Provent (or equivalent) will be below atmospheric pressure, it cannot be pressurised except under fault conditions such as severe piston blow-by (when you would have much more pressing concerns).
Your method of mounting the Provent looks very familiar! Click image to enlarge |
22nd Aug 2020 9:12pm |
Why change what looks to be a perfect solution? Rgds. Chris |
22nd Aug 2020 9:23pm |
Just an update on the Provent Copy - done nearly 3000 miles without any issues and drained it today, less than an egg cup full of mostly clear liquid. Rgds. Chris |
30th Mar 2021 9:11pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 427 |
Yeah but what did it taste like?
Seriously though, I’m surprised it’s mostly clear! I was expecting a dark oily residue from the crankcase. If it’s just condensation and moisture coming through and back into the intake, maybe it’s nothing to be that concerned about? The nugget stuff however looks ace and it certainly on the list of things to do! |
30th Mar 2021 9:20pm |
