Home > Maintenance & Modifications > Nugget Stuff Airbox
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Nugget Stuff Airbox
Part 1 - done.
Just need to sort the Hummel Pro-vent out now plus a couple of hoses.
 Rgds.
Chris
Post #850701 18th Aug 2020 3:00pm
Bluest
Excellent, this is top of my future mods list. 2007 110 TDCi Station Wagon XS
Post #850704 18th Aug 2020 3:05pm
Co1
Re: Nugget Stuff Airbox
Pacha wrote:
Part 1 - done.
Interested in your feedback Chris once you get a chance to give it a thorough test drive.
Post #850755 18th Aug 2020 6:47pm
Pacha
Once it's sorted you can have a drive Col. Rgds.
Chris
Post #850757 18th Aug 2020 6:50pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Remap, remap, remap
Bow down
Post #850808 18th Aug 2020 10:20pm
Pacha
We spoke, you know it! Rgds.
Chris
Post #850809 18th Aug 2020 10:23pm
Pacha
Ok all done.
Gone slightly lightly off piste - the 'Provent' is aneBay copy. After lots of research it appears to me that the internet scaremongering has no foundation when used on a TDCi. The standard system on a Defender without any catch can arrangement is a 19mm hose that goes from the rocker cover to the airbox - end of.
Using a 'Provent' simply adds a reservoir between the rocker cover and the airbox - it cannot be 'pressurised' in any way since 1) it is simply a reservoir in an 'open to atmosphere' hose, and, 2) the 'Provent' has a valve in the cap which prevents any overpressure in the first place.
The vent has been run through the wheel arch liner with a quarter turn valve next to the brake hose.
Will keep updating as use clocks up.
So far, engine runs like it always did.
 Rgds.
Chris
Post #851472 22nd Aug 2020 8:46pm
Zed
Nice one. Presumably the intake is sealed all the way to the RAI.
Have you driven it in anger yet and if so what kpa showed on the Informer? WARNING.
Post #851476 22nd Aug 2020 9:00pm
Pacha
Yep, completely sealed from snorkel to airbox. Rgds.
Chris
Post #851477 22nd Aug 2020 9:02pm
The Provent (or equivalent) will be below atmospheric pressure, it cannot be pressurised except under fault conditions such as severe piston blow-by (when you would have much more pressing concerns).
Your method of mounting the Provent looks very familiar!
Post #851481 22nd Aug 2020 9:12pm
Pacha
Why change what looks to be a perfect solution? Bow down Rgds.
Chris
Post #851486 22nd Aug 2020 9:23pm
Pacha
Pacha wrote:
Gone slightly lightly off piste - the 'Provent' is an eBay copy. After lots of research it appears to me that the internet scaremongering has no foundation when used on a TDCi. The standard system on a Defender without any catch can arrangement is a 19mm hose that goes from the rocker cover to the airbox - end of.
Just an update on the Provent Copy - done nearly 3000 miles without any issues and drained it today, less than an egg cup full of mostly clear liquid. Rgds.
Chris
Post #895002 30th Mar 2021 9:11pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Yeah but what did it taste like?
Seriously though, I’m surprised it’s mostly clear! I was expecting a dark oily residue from the crankcase. If it’s just condensation and moisture coming through and back into the intake, maybe it’s nothing to be that concerned about?
The nugget stuff however looks ace and it certainly on the list of things to do!
Post #895003 30th Mar 2021 9:20pm
