Home > Maintenance & Modifications > Rattle and Judder/Vibrations
Appleby
United Kingdom 2002 Defender 90 Td5 CSW Epsom Green
Hi,
My Td5 has recently started to rattle under acceleration and more worryingly a constant strong vibration has appeared, enough to rattle the dash/steering wheel, when the engine is under load (50mph cruising etc.).
I'm thinking my clutch may have gone, it's done 106,000 miles but I can't feel any slip and it still pulls away OK.
Has anyone else experienced this? I've read a few threads on clutch rattle but not seen anything about the juddering/vibrations.
Post #849430 12th Aug 2020 8:15am
Dinnu
Prop shafts? My rear propshaft seems like it will eventually loose one on the balance weights as it is only spot welded in place and rusting underneath. Have done 350mile, at speeds over 50mph, journey on difflock with front propshaft removed with no ill effects. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #849435 12th Aug 2020 8:27am
Naks
My Puma has started vibrating rather badly, feels like the rear prop is working its way loose/to death.
What could I replace it with? Or does it need new UJs?
Standard height with HD coils. --
Post #856670 18th Sep 2020 3:39pm
kenzle8a
Re: Rattle and Judder/Vibrations
Appleby wrote:
Hi,
My TD5 does the same, I suspect its the prop too, I've not had it that long but I don't think its the clutch as it doesn't have any signs of slip.
Post #856676 18th Sep 2020 4:32pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
The answer to nearly every question about Defenders is the propshaft U/Js need replacing.
The first one you ever do takes ages, is dirty and fiddly.
After that they’re quite straight forward, once you get the hang of it.
Many can’t be bothered, and just buy a new prop as they are quite cheap. 2002 td5 90 county hardtop
Post #856682 18th Sep 2020 5:42pm
