![]() | Home > Maintenance & Modifications > Rattle and Judder/Vibrations |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3543 ![]() ![]() ![]() |
Prop shafts? My rear propshaft seems like it will eventually loose one on the balance weights as it is only spot welded in place and rusting underneath. Have done 350mile, at speeds over 50mph, journey on difflock with front propshaft removed with no ill effects. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
My Puma has started vibrating rather badly, feels like the rear prop is working its way loose/to death.
What could I replace it with? Or does it need new UJs? Standard height with HD coils. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
My TD5 does the same, I suspect its the prop too, I've not had it that long but I don't think its the clutch as it doesn't have any signs of slip. |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 398 ![]() ![]() ![]() |
The answer to nearly every question about Defenders is the propshaft U/Js need replacing.
The first one you ever do takes ages, is dirty and fiddly. After that they’re quite straight forward, once you get the hang of it. Many can’t be bothered, and just buy a new prop as they are quite cheap. 2002 td5 90 county hardtop |
