Home > Puma (Tdci) > “Thud” on gearchange.
Page 2 of 2 <12
Thon
A thud when changing gear is commonplace as you have seen from the responses, and has diverse range of causes. Mine behaves the same, and I think most Pumas with original transmission components suffer from greater transmission slack than any of the preceding versions. Nothing in my drive train is judged as being excessively worn so I'm driving "around" the thud until such time as a definite culprit surfaces. Replacing components ranges from affordable (drive member flange) to a chunk of significance (diff) and personally I would take the opportunity to upgrade the component at that point, adding to the cost, hence my reluctance to renew components without proven cause.
Post #859674 4th Oct 2020 8:43am
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Just upgraded to Ashcroft HD drive shaft flanges as had a bit of play with the rear wheel hubs. Clunk or thud on gearchanges now gone Very Happy
Chris
Post #859755 4th Oct 2020 2:41pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Mine does it if i don't change at 2000rpm. i think its the clutch centreplate moving back and forth as it has a slight rattle on idle. 1953 80"
1987 mini city e
2011 90"
Post #859993 5th Oct 2020 9:15pm
As mentioned DM’s and or Prop UJ’s are typical culprits for this, usually the former at higher speeds and the latter for lower speeds but is variable. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #859996 5th Oct 2020 9:33pm
Page 2 of 2 <12
