![]() | Home > Maintenance & Modifications > Swivel grease |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2492 ![]() ![]() ![]() |
Witha stick at the same sort of angle on each side. If level is similar then, ok (sort of half level). If they got emulsionated with H2O then I guess you need to change the lub. Puma 110" SW
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
good suggestion.
thanks, i'll go and find a stick! ![]() |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
You have to put full lock on in both directions to check either side (full locking each time in opposite directions)
I used a wooden kebab stick at an angle, they should be around half full. |
