Home > Maintenance & Modifications > Swivel grease
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Swivel grease
Hi,
this is regarding a 300tdi. the swivels aren't losing any grease but they had a re-build and a grease sachet added about 2 years and 15k miles ago.
any idea how you check whether we need to add any more?
thanks BM52
Post #79156 5th Jul 2011 11:14pm
MK
Witha stick at the same sort of angle on each side. If level is similar then, ok (sort of half level). If they got emulsionated with H2O then I guess you need to change the lub. Puma 110" SW
Post #79162 6th Jul 2011 1:07am
bm52
good suggestion.
thanks, i'll go and find a stick! Thumbs Up BM52
Post #79324 7th Jul 2011 11:35am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
You have to put full lock on in both directions to check either side (full locking each time in opposite directions)
I used a wooden kebab stick at an angle, they should be around half full.
Post #79329 7th Jul 2011 12:52pm
