Home > Maintenance & Modifications > How to fix rattling sliding windows on 90/110
spudfan
Ireland
Found this on YouTube. Seems easy enough. Let me know if it works!
 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #833716 27th May 2020 4:51pm
Pugit666
United Kingdom 1998 Defender 90 300 Tdi CSW Alpine White
I have done tHis using the felt that he recommends. The first window was as he described and the felt was a couple of inches short. Did the other window last week, felt was 3” too long which was good. It does work and stops the window rattling. Did the first window a year ago and still good.
Post #833727 27th May 2020 6:21pm
spudfan
Ireland
Thumbs Up 1982 88" 2.25 diesel
Post #833728 27th May 2020 6:24pm
excossack
I did mine and used the Garrison Outfitters kit, Cured the rattle. Still leak. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #833774 27th May 2020 9:52pm
QuintinC
South Africa 2003 Defender 90 Td5 SW Alpine White
Done that, now it seems that the fixed rear part is rattling. Anyone else have that?
Post #835552 6th Jun 2020 6:48pm
QuintinC
Post #835554 6th Jun 2020 6:49pm
spudfan
Ireland
Completed this today with my daughter. Very easily done once you watch the video first. I bought three strips from Paddocks but you only need two full ones and two little add ons about three inches each. Big difference in the new felt and the remains of the old existing felt. Went for a test drive and all seems well. 1982 88" 2.25 diesel
Post #836393 10th Jun 2020 7:01pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
This is a much better solution to the felt:
https://www.woolies-trim.co.uk/product/1649/small-window-channel
Very easy to fit without removing the glass.
Post #836405 10th Jun 2020 7:50pm
spudfan
Ireland
The glass does not have to be removed to put in the new felt. 1982 88" 2.25 diesel
Post #836411 10th Jun 2020 8:12pm
Oldowner
I have used this channel on a couple of Puma 90s and also Wolf doortops with good effect.
Post #836418 10th Jun 2020 8:37pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
99p rubber door stop wedge.
sorted.
Post #836434 10th Jun 2020 9:33pm
ashfordsv
Ireland 2006 Defender 90 Td5 SW Java Black
I used black cable ties, I just cut off the heads and then jammed the ties into the top and bottom window gaps, works great Thumbs Up
Post #836629 11th Jun 2020 7:09pm
spudfan
Ireland
I did the cable tie thing as an interim stop rattling fix. But I wanted my daughter to be able to open and close the windows so we did the felt fix. Does not take long and it is easy to do. 1982 88" 2.25 diesel
Post #836645 11th Jun 2020 8:36pm
stephan123
What's the best way to get the new felt to go around the corner of the windows??
Post #836651 11th Jun 2020 9:04pm
spudfan
Ireland
You just make a "v" with the felt and feed it into the channel . It is all in the video and it is very easy to do. 1982 88" 2.25 diesel
Post #836656 11th Jun 2020 9:19pm
