![]() | Home > Maintenance & Modifications > How to fix rattling sliding windows on 90/110 |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683 ![]() ![]() ![]() |
I pulled all the felt out and then fed the wollies channel round the window, using silicon spray to lubricate it. It creased slightly on the corners but after a day or two with the windows firmly closed they sat fine with no creases |
sammy Member Since: 18 Jun 2020 Location: Oxford Posts: 5 ![]() ![]() ![]() |
I tried this fix today and it worked pretty well
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1248 ![]() ![]() ![]() |
@Retroanaconda has a slightly extreme method in his 90 - a screwdriver down between the door and the glass
![]() 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
jcw Member Since: 11 Sep 2016 Location: Gloucestershire Posts: 171 ![]() ![]() ![]() |
Will 3m be enough to complete both sides? |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886 ![]() ![]() ![]() |
I just measured how far i have left on the second window and its 60cm so 3m will cover it
