Home > In Car Electronics > Wiring Anderson connector from winch?
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Morning all.
After having to give several jump starts in recent weeks (great how people assume that because you have a Defender, you don’t mind giving a jump start, changing a wheel etc etc) I’ve decided to fit an Anderson connector and I’ll probably put it on the front bumper for convenience.
I have read Leeds’ excellent guide on the forum but was wondering if I could take the power and -ve connections from my winch, rather than run it all the way back to the battery. The advantage being less cable and it already has an isolator switch in the cab.
Thanks in advance.
Post #833243 25th May 2020 9:26am
landy andy
Yes. I did similar on my tdci when I ran cables into engine bay, in, and out of Anderson connector then to the winch. I preferred the idea of the connections being under the bonnet. That way they are protected from the elements, no one can back power the winch or try vehicle, and less obvious.
Andy.
Post #833245 25th May 2020 9:36am
Also has the advantage that you can easily power your winch externally if the need arises.
Post #833250 25th May 2020 9:59am
The Zee
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
Re: Wiring Anderson connector from winch?
Any chance of posting a link to the guide, since I was thinking of doing something similar.... Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
Post #833286 25th May 2020 2:12pm
JoolsB
Post #833295 25th May 2020 2:57pm
JoolsB
Andy.
Cheers Andy, so does that mean you’ve got an Anderson under the bonnet and you can swap your winch or jump leads or whatever,depending on need?
Post #833297 25th May 2020 3:00pm
jst
I have a set inside the rear door, works well for jump start or powering trailer winch Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #833300 25th May 2020 3:02pm
JoolsB
Hmmm, this gets better - so for this to work, I’d just splice the power and -ve off the winch connections and both would be energised - or not - from the switch in the cab?
Blackwolf - with this arrangement, would I still be able to jump my wagon from someone else’s if I needed to?
Thanks again all.
Post #833301 25th May 2020 3:05pm
JoolsB
I did think about that, but it’s quite ‘busy’ inside my back door as it is Neutral
Post #833302 25th May 2020 3:06pm
JoolsB
Hmmm, I just read that back....it’s all getting a bit Carry On in the Defender.
I mean there’s speakers and seats and 12v sockets already Confused
Post #833304 25th May 2020 3:08pm
Thanks again all.
Yes. To use the winch from your own vehicle battery or to jump start (either your own or another vehicle) switch on the winch isolator. To power your winch from another vehicle just connect jump leads without switching on the isolator.
Post #833314 25th May 2020 4:10pm
JoolsB
Thanks for that, I’ll get some bits ordered.
Post #833334 25th May 2020 6:03pm
