![]() | Home > In Car Electronics > Wiring Anderson connector from winch? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5948 ![]() ![]() |
Yes. I did similar on my tdci when I ran cables into engine bay, in, and out of Anderson connector then to the winch. I preferred the idea of the connections being under the bonnet. That way they are protected from the elements, no one can back power the winch or try vehicle, and less obvious.
Andy. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17823 ![]() ![]() ![]() |
Also has the advantage that you can easily power your winch externally if the need arises.
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 295 ![]() ![]() ![]() |
Any chance of posting a link to the guide, since I was thinking of doing something similar.... Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 167 ![]() ![]() ![]() |
Here you go Z
https://www.defender2.net/forum/topic4528....1e4339c4cd |
Cheers Andy, so does that mean you’ve got an Anderson under the bonnet and you can swap your winch or jump leads or whatever,depending on need? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8290 ![]() ![]() ![]() |
I have a set inside the rear door, works well for jump start or powering trailer winch Cheers
Hmmm, this gets better - so for this to work, I’d just splice the power and -ve off the winch connections and both would be energised - or not - from the switch in the cab? Blackwolf - with this arrangement, would I still be able to jump my wagon from someone else’s if I needed to? Thanks again all. |
I did think about that, but it’s quite ‘busy’ inside my back door as it is ![]() |
Hmmm, I just read that back....it’s all getting a bit Carry On in the Defender.
I mean there’s speakers and seats and 12v sockets already ![]() |
Yes. To use the winch from your own vehicle battery or to jump start (either your own or another vehicle) switch on the winch isolator. To power your winch from another vehicle just connect jump leads without switching on the isolator. |
Thanks for that, I’ll get some bits ordered.
