![]() | Home > Maintenance & Modifications > Coil springs part numbers? |
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 333 ![]() ![]() ![]() |
And to hijack a thread if thats ok I am sort of in the same boat.
I have a 1998 300TDI, 2 seat utility, WA chassis number so the last before the XA ones come out. For the life of me I cant find what springs to put on? I have got the shocks and supporting hardware sorted, just need to know what OEM springs to put on? I have used the search function and still no closer to what I need? Sorry if I have derailed this thread, more than happy to start a new one if needed. TIA |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2025 ![]() ![]() ![]() |
No Worries, i just can't seem to make sense of the vast array of different ones out there
I did want the Alive comfort Standard height but they are not advertised on their website site and no reply to enquiries so the best way forward is another set of Genuine 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Front coil springs are REB500220, colour code Blue/Yellow, which now appears to be the standard front spring for all Puma models.
Rear springs for a 110 USW are RKB101111, colour code Brown/Purple. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
Here you go,
http://www.bilashakaflowers.com/LandroverSprings.htm |
Thank you to all. I thought it was those however they said from chassis XA onwards and couldn't find anything for pre XA? Thanks everyone ![]() |
Front drivers side, NRC9446, Green Front passenger side, NRC9447, Blue Rear drivers side, RKB101230, Yellow/Red Rear passenger side, RKB101240, Yellow/White These are the standard duty springs. There are also HD versions available. https://www.lrworkshop.com/diagrams/land-r...ings_52610 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thank you very much!
![]() So many coils out there and so many bad stories, genuine is a lot less hassle ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) Last edited by bear100 on 18th May 2020 11:40am. Edited 1 time in total |
I believe The Utility has the HD springs as opposed to the standard? Mine has the brown/purple on the rear |
You could be right. For some unknown reason, I thought that Danny had a 90 and have given the details for that
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks chaps. Looks like I will be trying to find a set of the Brown/Purple.
Any ones to avoid or recommendations of suppliers etc? |
Depends how much you want to pay. Genuine here:
https://rimmerbros.com/Item--i-RKB101111 Or pattern ones for a lot less: https://paddockspares.com/rkb101111-spring-road.html I've even got a pair of used (approx. 54k miles) ones in the garage that you can have for free, if you want to come and get them. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2671 ![]() ![]() ![]() |
They are all here: https://www.defender2.net/forum/topic13312-15.html
or here: http://bilashakaflowers.com/LandroverSprings.htm ![]() |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 570 ![]() ![]() ![]() |
lrsurplus on eBay have new take off springs listed.
You send them a message with the colour code you require and they’ll get back to you. I bought new front and rear sets off them a couple of months ago, but......they were £50 a pair then, now they are £125 a pair! Still a saving on new genuine parts though I guess. https://www.ebay.co.uk/itm/143556653678 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
So just to confuse matters I have cleaned off my nearside spring and its RED/GREEN.
I am guessing Brown/Purple will still be ok? |
