Home > Technical > Rear A-frame pivot bracket bolt torque |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1186 |
Hmm, makes me question the quality of the ball-joint. I've quite happily tightened mine with a breaker bar with both feet braced against the axle. Definitely more than 174Nm of torque applied to it that way.
Sorry just realised you weren't talking about the ball joint itself I've normally just done those up nice and tight - they're a fine thread with nylocs so provided it's clamped everything together properly then they shouldn't come undone. If in doubt look up the torque required for the bolt diameter / thread combination - that'll be the definitive source. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
9th May 2020 8:41pm |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 723 |
Yes I should do that. I have a habit of doing everything up way too tight, which means I either break them directly (as in here) or can never get them undone again.
I'm trying to solve the problem with much use of the torque wrench, but that relies on the right information being in the books! 2005 Td5 90 XS 1989 V8 110 CSW |
9th May 2020 8:52pm |
84 lbft = 115 Nm
Grade 5 1/2 unf bolt 85 lbft -----------Grade 8 1/2 unf bolt 120 lbft Had the same problem start of the year fond the gross referencing with the pre-93 Land Rover workshop manual with 115 Nm: for two bolts for the rear A-frame pivot bracket bolts look up max torque for 1/2 unf bolt grade 5 and 8 and pre-93 Land Rover workshop manual torque 115 Nm make sens LR RAV 1999 to 2002 my supplement needs to be prof read and red pen to add missing texts and sort the bad texts if Haynes have coped it you will have same problem |
9th May 2020 8:53pm |
Ah that's interesting, thanks Dorset. I shall be inspecting my bolts for markings from now on 2005 Td5 90 XS
1989 V8 110 CSW |
9th May 2020 10:42pm |
Grade 5 = 8.8 metric --------------------- Grade 8 = 10.9 metric
10th May 2020 8:25am |
