Home > Technical > Rear A-frame pivot bracket bolt torque
Hufflepuff
I think that the Haynes manual has got me again :/
It quotes the rear pivot bracket bolts as needing to be 174 Nm. Well that nicely stripped the thread for me on the front one.
It did seem quite a lot I must admit, but then it is a fairly important mounting, and they are pretty big bolts (1/2" I think).
Nothing that the angry tool couldn't rectify, but a right faff as I now need to source new bolts and nuts:
Why can't they just get these important things right in the book.
Cross referencing with the pre-93 Land Rover workshop manual looks like it has a much better value of 115 Nm:
I'm struggling to to find the information in the newer Workshop manual though - it says section 64 for the rear suspension but I can't find any reference to this there? 2005 Td5 90 XS
1989 V8 110 CSW
Post #830135 9th May 2020 7:24pm
sako243
Hmm, makes me question the quality of the ball-joint. I've quite happily tightened mine with a breaker bar with both feet braced against the axle. Definitely more than 174Nm of torque applied to it that way.
Sorry just realised you weren't talking about the ball joint itself Embarassed
I've normally just done those up nice and tight - they're a fine thread with nylocs so provided it's clamped everything together properly then they shouldn't come undone. If in doubt look up the torque required for the bolt diameter / thread combination - that'll be the definitive source. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #830148 9th May 2020 8:41pm
Hufflepuff
Yes I should do that. I have a habit of doing everything up way too tight, which means I either break them directly (as in here) or can never get them undone again.
I'm trying to solve the problem with much use of the torque wrench, but that relies on the right information being in the books! 2005 Td5 90 XS
1989 V8 110 CSW
Post #830150 9th May 2020 8:52pm
dorsetsmith
84 lbft = 115 Nm
Grade 5 1/2 unf bolt 85 lbft -----------Grade 8 1/2 unf bolt 120 lbft
Had the same problem start of the year fond the gross referencing with the pre-93 Land Rover workshop manual with 115 Nm: for two bolts for the rear A-frame pivot bracket bolts
look up max torque for 1/2 unf bolt grade 5 and 8 and pre-93 Land Rover workshop manual torque 115 Nm make sens
LR RAV 1999 to 2002 my supplement needs to be prof read and red pen to add missing texts and sort the bad texts Banging Head if Haynes have coped it you will have same problem
Post #830152 9th May 2020 8:53pm
Hufflepuff
Ah that's interesting, thanks Dorset. I shall be inspecting my bolts for markings from now on Smile 2005 Td5 90 XS
1989 V8 110 CSW
Post #830167 9th May 2020 10:42pm
dorsetsmith
Grade 5 = 8.8 metric --------------------- Grade 8 = 10.9 metric
Post #830189 10th May 2020 8:25am
