Home > Technical > Additional switches and that sort of thing
Happyoldgit
I just thought I'd post a general heads up regarding the sort of thing I've used in the past to control additional electrical circuits and accessories - namely switch boxes and panels designed for use in emergency vehicles. These can be obtained quite cheaply over in the USA and some have the advantage of being fairly easy to move from vehicle to vehicle at renewal time. Some have inbuilt relays while others can be hooked up to external self sourced relays or manufacturer relay boxes or power / distrubution centres.
While they can be got over here from the likes of EVS, Woodway, Premier Hazard etc I've usually obtained mine direct from the States, in fact the likes of Federal Signal SW300 boxes which can easily be mounted on the front face of Defender cubby boxes turn up regularly on Ebay secondhand.
http://www.fedsig.com/docs/256A568.pdf
More here...
http://www.strobesnmore.com/index.php?cPath=11
http://www.sirennet.com/switch.html Steve.
http://forums.lr4x4.com
Post #78364 29th Jun 2011 3:57pm
Eduardo
Miserableolgit,
Good gadget at a reasonable price Mr. Green
You dont need to "modify" the dash if you like to install several switches and save installation time.
Thanks for the links.
Cheers! Eduardo
Post #78393 29th Jun 2011 7:52pm
Happyoldgit
I like them for those very reasons Thumbs Up Steve.
Post #78508 30th Jun 2011 6:13pm
Jurassic Defender
Portugal 2000 Defender 110 2.5 TD HT Coniston Green
https://www.youtube.com/watch?v=SMZhPTJBhQA
Sharing here how I did mine hazard switch conversion to a Carlin switch Thumbs Up
Post #1068562 28th May 2025 2:07am
