![]() | Home > Technical > Additional switches and that sort of thing |
I just thought I'd post a general heads up regarding the sort of thing I've used in the past to control additional electrical circuits and accessories - namely switch boxes and panels designed for use in emergency vehicles. These can be obtained quite cheaply over in the USA and some have the advantage of being fairly easy to move from vehicle to vehicle at renewal time. Some have inbuilt relays while others can be hooked up to external self sourced relays or manufacturer relay boxes or power / distrubution centres.
While they can be got over here from the likes of EVS, Woodway, Premier Hazard etc I've usually obtained mine direct from the States, in fact the likes of Federal Signal SW300 boxes which can easily be mounted on the front face of Defender cubby boxes turn up regularly on Ebay secondhand. http://www.fedsig.com/docs/256A568.pdf More here... http://www.strobesnmore.com/index.php?cPath=11 http://www.sirennet.com/switch.html Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Miserableolgit,
Good gadget at a reasonable price ![]() You dont need to "modify" the dash if you like to install several switches and save installation time. Thanks for the links. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
I like them for those very reasons
![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Jurassic Defender Member Since: 28 May 2025 Location: Lisbon Posts: 13 ![]() ![]() ![]() |
https://www.youtube.com/watch?v=SMZhPTJBhQA
Sharing here how I did mine hazard switch conversion to a Carlin switch ![]() |
