Home > Maintenance & Modifications > Security screw bits
ericvv
Security screw bits
Here is a picture of the security screws in my bonnet hinges. They seem to come loose now so need tightening.
What is name or type of those security screws and of the bits you need to tighten those screws? I guess you can buy those without too much difficulty, maybe even on amazon?
Thanks, Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #828560 29th Apr 2020 7:35pm
Bluest
Looks like security Torx to me 2007 110 TDCi Station Wagon XS
Post #828561 29th Apr 2020 7:39pm
Green Machine
Also known as 'pin torx' 2005 Td5 | 90 Station Wagon | Tonga Green
Post #828567 29th Apr 2020 7:51pm
Sulisuli
https://www.dewalt.com/products/accessorie...et/dwax200
This should help Ericv Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #828568 29th Apr 2020 7:55pm
ARC99
Plenty on line, don't buy cheap as the stars on the bits round off, the normally fit into 1/4 hex socket. Don't make old people mad.
Richard
Post #828569 29th Apr 2020 7:59pm
As noted above, they are pin Torx, and unfortunately bits are so common that they are useless as a security measure. It's actually harder to buy solid Torx bits than it is pin Torx.
Post #828571 29th Apr 2020 8:03pm
en48
United Kingdom 2009 Defender 90 Puma 2.4 CSW Bonatti Grey
I got a Laser set off Amazon - 20 odd bits I think. Really decent quality.
I'm sure there are other good ones out there - but as has been said, there are PLENTY of gash ones too... (Speaking from bitter experience!)
Actually, just looked. Laser 5031 - about £25 on Amazon.
As I say, I'm sure there are other 'good' ones, and probably cheaper.
Post #828602 29th Apr 2020 10:43pm
ericvv
Post #828605 30th Apr 2020 3:53am
macfrank
Indeed. Sad A while ago I ordered a set of "security" door bolts. After replacing the first one I noted I had not used the "security" bit provided but a bit from my toolbox - which I then noticed was pin torx... Needless to say I removed the first and went the ball-bearing route instead...
Post #828675 30th Apr 2020 2:18pm
