![]() | Home > Maintenance & Modifications > Security screw bits |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Here is a picture of the security screws in my bonnet hinges. They seem to come loose now so need tightening.
What is name or type of those security screws and of the bits you need to tighten those screws? I guess you can buy those without too much difficulty, maybe even on amazon? Thanks, Eric Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4340
Looks like security Torx to me 2007 110 TDCi Station Wagon XS
| Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226
Also known as 'pin torx' 2005 Td5 | 90 Station Wagon | Tonga Green
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
https://www.dewalt.com/products/accessorie...et/dwax200
This should help Ericv 2008 SVX 90 2000 XS TD5 90 |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18033
As noted above, they are pin Torx, and unfortunately bits are so common that they are useless as a security measure. It's actually harder to buy solid Torx bits than it is pin Torx.
| en48 Member Since: 17 Jul 2019 Location: Wiltshire Posts: 38
I got a Laser set off Amazon - 20 odd bits I think. Really decent quality.
I'm sure there are other good ones out there - but as has been said, there are PLENTY of gash ones too... (Speaking from bitter experience!) Actually, just looked. Laser 5031 - about £25 on Amazon. As I say, I'm sure there are other 'good' ones, and probably cheaper. |
Thanks everybody. Going to check where to find a decent set.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138
Indeed. |
