Home > Td5 > TD5 90 (2004) - Which Anti Roll Bar
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
I have a 2004 TD5 90. It has 200,000 on it now so as ever it's a constant fixer upper! Looking at a rear anti roll bar at the moment. I am considering the 25.4mm Extreme 4x4 or the Alive Tuning one. Thoughts and recommendations please. 80% road use the only 20% off road which is mostly green lane type stuff.
Tank
Post #826992 22nd Apr 2020 10:52am
lightning
I wouldn’t bother with an “uprated” one, best to fit the Land Rover OE one.
Although anti-roll bars don’t generally wear out.
If you do need a new one, don’t pay new prices, try Twisted Automotive for a new “take off” one at about £18
Post #833201 24th May 2020 11:33pm
bankz5152
Standard ARB is 19mm Alives is 32mm i think. Makes quite the difference in corner if youre that way inclined.
Post #833215 25th May 2020 6:12am
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
My first 90 no anti roll first corner on a country lane almost ended on it side after 3 years with a cart sprung series 2 88 with xcl skinny tyres that would drift nicely at roundabouts current defender county td5 with factory anti roll bars corners almost flat Christ knows what trouble I would get into with 32mm anti roll bars tbh the std factory fit is pretty good
Post #833230 25th May 2020 7:42am
Tank
I ended up with the Alive one and I am very pleased with the results.
Post #833258 25th May 2020 10:37am
lightning
If the Alive one is “uprated” then you need to fit the matching front one as well, or you could mess up the handling of the vehicle.
If you were in an accident and it was discovered that you’d altered the suspension it could affect your claim, as the loss adjusters could argue that it unduly affected the characteristics of the vehicle.
Post #833574 26th May 2020 9:39pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I don't know how you guys drive but I have no ARB's under my 90 td5 and also had no ARB under my CT Disco.
Yes they hang over in a fast corner but never got one on 2 wheels so surely not on it's side. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #833917 28th May 2020 6:50pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
With a defender its always a compromise. If you want to hit roundabouts as fast as you can then get an uprated (thicker) one. I thought about doing mine but read reports of a harsher ride as each side of the axle cant push up as easily/individually.
Also an uprated one with decrease flex a lot. Hence why nost die hard off roaders dont have arb's at all.
Another thing to consider is load. If youve got a roof rack with gear up top and a roof tent maybe the uprated one would be an idea as i dont think the standard one is up to the task. When i load up the back of my 90 really heavily its a bit wallowy even with the standard bar.
I think the genuine LR one is a good compromise between road handling and flex.
Post #834646 1st Jun 2020 6:30pm
Green Machine
As with so many things, it was designed that way for a reason, so keep it standard. I have learnt this lesson to my cost over the years - a lot of things I have 'upgraded' I have ended up reverting to standard. Not always the case, but often times it is.
Obviously if your Defender is very modified away from its original specification (weight, performance) then 'upgraded' components start to make sense.
All of these things are a balance, but Land Rover have spent time and money (believe it or not) reaching a specification that works and achieves the optimum balance of characteristics, so it makes sense to take advantage of that. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #834649 1st Jun 2020 6:45pm
