![]() | Home > Maintenance & Modifications > Help - Rear cross member bolts |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3750 ![]() ![]() ![]() |
Are they not something to do with the rear seat belts!
Look up underneath the wheel arches and you'll see two substantial brackets from the back face of the crossmember up to the underside of the tub which, as Co1 says, are part of the seat belt supports.
You can probably take them out without issue* as the bracket is also fixed at the top but don't forget to put them back in again. *That doesn't mean that they may not be difficult to remove! Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
Thanks for that, thought they were to do with the rear seat belts, may just loosen them off so I get behind them.
Related, am going to replace the 10 above those, the body to rear crossmember bolts. I see the new ones come with a nunc lock type of nut. Do the originals as I imagine it must be quite difficult to get purchase on the nut to remove? Any tips? |
The ten body to crossmember bolts thread into captive nuts so you won't need to get behind them. Darren
Well that will make it a doddle of a job, strange all the sets come with nuts!
It's different on older models - pre-TD5, from memory. Darren
This is on a 2007 Tdci
I see there are variations in the stainless versions, button head like these which is the profile already fitted: https://www.ebay.co.uk/itm/LAND-ROVER-DEFE...xyJs5RZnhC or more barreled like these: https://www.ebay.co.uk/itm/LAND-ROVER-DEFE...XQsmFRcXhw Also all seem to be A2 steel, presume this is sufficiant? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
Ah, an optimist! ![]() |
Always!
Any thoughts on my nuts... Which bolts to go for?,
Is it just a personal preference? |
Yes, A2 is fine for this application. The choice of head is personal choice, as much as anything. I probably wouldn't use standard hex head bolts as it's more likely to damage the paint with a socket.
Don't forget to isolate the stainless bolt from the body. Nylon washers are useful for this but also a dab of something like Duralac or Weicon anti-seize paste on the threads is a good idea. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Good to know, thanks
