Home > Maintenance & Modifications > Help - Rear cross member bolts
Stiff1
So removed the NAS step some time ago to referb it and with all this time on my hands thought I would freshen the rear cross member (seems a popular job at the moment)
I was going to remove these 4 bolts to clean up and paint the cross member but had second thoughts.
What role do they play in a 110 CSW 7 seater?
Is there a load spreader that will fall out if I remove both from a side at the same time or is there no harm in taking them all out at the same time?
Thanks in advance.
Post #825687 16th Apr 2020 1:08am
Co1
Are they not something to do with the rear seat belts!
Post #825692 16th Apr 2020 6:10am
Look up underneath the wheel arches and you'll see two substantial brackets from the back face of the crossmember up to the underside of the tub which, as Co1 says, are part of the seat belt supports.
You can probably take them out without issue* as the bracket is also fixed at the top but don't forget to put them back in again.
*That doesn't mean that they may not be difficult to remove! Darren
Post #825715 16th Apr 2020 8:21am
Stiff1
Thanks for that, thought they were to do with the rear seat belts, may just loosen them off so I get behind them.
Related, am going to replace the 10 above those, the body to rear crossmember bolts. I see the new ones come with a nunc lock type of nut. Do the originals as I imagine it must be quite difficult to get purchase on the nut to remove? Any tips?
Post #825788 16th Apr 2020 12:45pm
The ten body to crossmember bolts thread into captive nuts so you won't need to get behind them. Darren
Post #825789 16th Apr 2020 12:58pm
Stiff1
Well that will make it a doddle of a job, strange all the sets come with nuts!
Post #825791 16th Apr 2020 1:10pm
It's different on older models - pre-TD5, from memory. Darren
Post #825795 16th Apr 2020 1:17pm
Stiff1
This is on a 2007 Tdci
I see there are variations in the stainless versions, button head like these which is the profile already fitted:
https://www.ebay.co.uk/itm/LAND-ROVER-DEFE...xyJs5RZnhC
or more barreled like these:
https://www.ebay.co.uk/itm/LAND-ROVER-DEFE...XQsmFRcXhw
Also all seem to be A2 steel, presume this is sufficiant?
Post #825796 16th Apr 2020 1:17pm
Ah, an optimist! Rolling with laughter
Post #825797 16th Apr 2020 1:21pm
Stiff1
Always!
Post #825798 16th Apr 2020 1:22pm
Stiff1
Any thoughts on my nuts... Which bolts to go for?,
Is it just a personal preference?
Post #825799 16th Apr 2020 1:23pm
Yes, A2 is fine for this application. The choice of head is personal choice, as much as anything. I probably wouldn't use standard hex head bolts as it's more likely to damage the paint with a socket.
Don't forget to isolate the stainless bolt from the body. Nylon washers are useful for this but also a dab of something like Duralac or Weicon anti-seize paste on the threads is a good idea. Darren
Post #825800 16th Apr 2020 1:25pm
Stiff1
Good to know, thanks
Post #825816 16th Apr 2020 4:14pm
