Home > Puma (Tdci) > Door card, alternative fixing method
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
Of course, half the fir-tree fixings on my door cards are broken and missing. Has anyone tried to do it differently? I’ve been thinking of drilling holes where each fir-tree is located and screwing the cards on with the screws threading into the plastic bushes in the door. I think If they were torx dome head stainless, it would look quite appropriate and be very solid.
Post #825609 15th Apr 2020 7:14pm
Mdm
you can do the drill and screw idea bu the plastic bushes will spin in the door. a better way is to rivnut your door and then use shiny bolts.
the downside is the door card is fairly flimsy.
i have seen them with fibreglass on the rear to fix them and add strength.
good clips work well for what they are
Post #825611 15th Apr 2020 7:25pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
I had a load of broken clips when I took my door cards off. I followed this you tube vid and it seemed to work on most of them.
Not the greatest bit of design in the world though!
Post #827474 24th Apr 2020 9:25pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
You can slam some roofing screws through in a temper but the final finish is a bit suboptimal Whistle
PS. mind the window glass Big Cry ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #827505 25th Apr 2020 1:11am
Gasher
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Bonatti Grey
The video clip posted by JoolsB is spot on I've tried it and its a very good solution.
Only one word of warning and that the door card has very little depth in some places making it difficult to accommodate a screw so I've had in the thinnest parts had to cut the screw down to avoid it piercing the vinyl.
All the the best
Gasher
Post #828002 27th Apr 2020 5:34pm
