![]() | Home > Puma (Tdci) > Door card, alternative fixing method |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1678 ![]() ![]() |
you can do the drill and screw idea bu the plastic bushes will spin in the door. a better way is to rivnut your door and then use shiny bolts.
the downside is the door card is fairly flimsy. i have seen them with fibreglass on the rear to fix them and add strength. good clips work well for what they are |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 171 ![]() ![]() ![]() |
I had a load of broken clips when I took my door cards off. I followed this you tube vid and it seemed to work on most of them.
Not the greatest bit of design in the world though! |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
You can slam some roofing screws through in a temper but the final finish is a bit suboptimal
![]() PS. mind the window glass ![]() 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Gasher Member Since: 19 Apr 2020 Location: E Sussxe Posts: 12 ![]() ![]() ![]() |
The video clip posted by JoolsB is spot on I've tried it and its a very good solution.
Only one word of warning and that the door card has very little depth in some places making it difficult to accommodate a screw so I've had in the thinnest parts had to cut the screw down to avoid it piercing the vinyl. All the the best Gasher |
