Home > Off Topic > Home made busbar
kmac
Home made busbar
I want to build a busbar for my dual battery install
I will connect the factory installed earth cable to the busbar and then connect each of the two batteries to the busbar.
Will save me from drilling another hole on the battery box to run a cable to the transmission casing
I can get a 3.2mm thick copper strip - 25mm wide and 100mm long for less that £5. Copper is 99.9% pure
How many amps would that be good for? I have see a video on the web which says 1.4 amps per 1 sq. mm of copper but find that a bit odd as doesn't say how thick the copper is. Any engineers care to comment?
To buy, a 500Amp busbar is around 50 squids
Post #825254 14th Apr 2020 5:05pm
rallysteve
if your batteries are next to each other, why not just link the negative terminals together with a short length of battery cable?
I have done this with my own setup as it was the neatest option with the least connections.
Post #825255 14th Apr 2020 5:08pm
kmac
It is well nigh impossible to connect anything else to the standard earth connector on the Puma.
How did you manage that? Unless I can get a ring lug that fits over the battery post
Post #825256 14th Apr 2020 5:13pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
Busbars are easy enough. I've done mine a slightly unorthodox way but it works well. It was the only way to do it to wrangle 500a of power in such a short space, instead of using 95mm cable (which I've used everywhere else in the split charge).
This was 20mm wide, 5mm thick mains busbar copper (giving me 100m2 CSA). In terms of calculating current on copper, go with the CSA (Cross sectional area in mm2) which is somewhat irrelevant as to its makeup between solid or stranded for the currents and distances we're talking about.
In terms of linking the two batteries, I use 10mm Stud terminals and I reterminated the factory cables to suit.
https://www.durite.co.uk/s/c/wiring-access...-10mm-stud
 North Cumbria Search and Rescue - Team Leader
Post #825259 14th Apr 2020 5:26pm
kmac
Very cool set-up.
I've gone for two 3.2mm strips, 25mm wide and 100mm long.
Based on your calcs more than enough
I'm using 40mm2 cable for the rest of it as I am not expecting 500Amps other than when cranking.
Have you insulated your strips with heatshrink? or something else?
Post #825262 14th Apr 2020 5:38pm
Re: Home made busbar
That will be 1 mm^2 of CSA, so your 3.2mm x 25mm strip, which has a CSA of 80mm^2 would, using that formula, be good for 112 Amperes.
Post #825265 14th Apr 2020 5:42pm
DuncanS
My strips were done with one layer of really big 3:1 glue shrink (clear) (to ensure a thick sleeve) with a layer of 2:1 on top in red for appropriate colour. North Cumbria Search and Rescue - Team Leader
Post #825266 14th Apr 2020 5:45pm
kmac
Thanks Duncan and Mr Wolf
I've gone for double strip so 6.4mm X 25mm
Post #825270 14th Apr 2020 6:05pm
kmac
I'm not sure of their formula
95mm^2 cable is normally rated for between 240 and 300 Amps continuous
I will have a cross section of 6.4mm *25mm so 160mm^2
Should be good for more than 224Amps no?
Edit: Actually some sites say 95mm^2 is good for 500 Apms
Post #825272 14th Apr 2020 6:13pm
Yes, I think that the formula is completely wrong, but I was trying to explain its application!
Post #825282 14th Apr 2020 6:55pm
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
What is this strange language you clever people talk
Post #825287 14th Apr 2020 7:14pm
kmac
Thanks Mr Wolf - finally got it when Duncan mentioned it refers to the cross sectional area (which in retrospect is obvious now as that is how cables are rated (in simplist terms, I know there are all kinds of complications with number of cores and strands per core etc)
Post #825509 15th Apr 2020 11:17am
DuncanS
Don't always trust the CSA figure purely for rating. Whilst the CSA does provide the direct current rating, you also need to factor in the insulation type and the strands. Hence why the traditional PVC 1mm2 cable is approx 8amps and the Thinwall 1mm2 cable which is more modern is 16amps.
The easiest bet when sizing a cable is just look at what the cable is rated for in Amps. Obviously the only reason we're having the discussion is that you were after solid copper understandably haha! I personally don't use any PVC wherever possible as Thinwall is much tougher and lighter (and apparently I never do "little" amounts of cabling on my projects) North Cumbria Search and Rescue - Team Leader
Post #825512 15th Apr 2020 11:25am
kmac
Thanks Duncan - I use Thinwall as well. It is the cooling properties that allow the higher amps I believe.
Anyway for my busbar I am going to go with a CSA of 6.4mm *25mm
Post #825520 15th Apr 2020 11:52am
dorsetsmith
http://copperalliance.org.uk/uploads/2018/...usbars.pdf
Post #825540 15th Apr 2020 1:08pm
