![]() | Home > Off Topic > Home made busbar |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
if your batteries are next to each other, why not just link the negative terminals together with a short length of battery cable?
I have done this with my own setup as it was the neatest option with the least connections. Steve 02' 110 TD5 Double Cab Rebuild Thread |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
It is well nigh impossible to connect anything else to the standard earth connector on the Puma.
How did you manage that? Unless I can get a ring lug that fits over the battery post |
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
Busbars are easy enough. I've done mine a slightly unorthodox way but it works well. It was the only way to do it to wrangle 500a of power in such a short space, instead of using 95mm cable (which I've used everywhere else in the split charge).
This was 20mm wide, 5mm thick mains busbar copper (giving me 100m2 CSA). In terms of calculating current on copper, go with the CSA (Cross sectional area in mm2) which is somewhat irrelevant as to its makeup between solid or stranded for the currents and distances we're talking about. In terms of linking the two batteries, I use 10mm Stud terminals and I reterminated the factory cables to suit. https://www.durite.co.uk/s/c/wiring-access...-10mm-stud ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge North Cumbria Search and Rescue - Team Leader |
Very cool set-up.
I've gone for two 3.2mm strips, 25mm wide and 100mm long. Based on your calcs more than enough I'm using 40mm2 cable for the rest of it as I am not expecting 500Amps other than when cranking. Have you insulated your strips with heatshrink? or something else? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17996 ![]() ![]() ![]() |
That will be 1 mm^2 of CSA, so your 3.2mm x 25mm strip, which has a CSA of 80mm^2 would, using that formula, be good for 112 Amperes. |
My strips were done with one layer of really big 3:1 glue shrink (clear) (to ensure a thick sleeve) with a layer of 2:1 on top in red for appropriate colour. North Cumbria Search and Rescue - Team Leader |
Thanks Duncan and Mr Wolf
I've gone for double strip so 6.4mm X 25mm |
I'm not sure of their formula 95mm^2 cable is normally rated for between 240 and 300 Amps continuous I will have a cross section of 6.4mm *25mm so 160mm^2 Should be good for more than 224Amps no? Edit: Actually some sites say 95mm^2 is good for 500 Apms |
Yes, I think that the formula is completely wrong, but I was trying to explain its application!
Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 285 ![]() ![]() ![]() |
What is this strange language you clever people talk
Thanks Mr Wolf - finally got it when Duncan mentioned it refers to the cross sectional area (which in retrospect is obvious now as that is how cables are rated (in simplist terms, I know there are all kinds of complications with number of cores and strands per core etc) |
Don't always trust the CSA figure purely for rating. Whilst the CSA does provide the direct current rating, you also need to factor in the insulation type and the strands. Hence why the traditional PVC 1mm2 cable is approx 8amps and the Thinwall 1mm2 cable which is more modern is 16amps.
The easiest bet when sizing a cable is just look at what the cable is rated for in Amps. Obviously the only reason we're having the discussion is that you were after solid copper understandably haha! I personally don't use any PVC wherever possible as Thinwall is much tougher and lighter (and apparently I never do "little" amounts of cabling on my projects) North Cumbria Search and Rescue - Team Leader |
Thanks Duncan - I use Thinwall as well. It is the cooling properties that allow the higher amps I believe.
Anyway for my busbar I am going to go with a CSA of 6.4mm *25mm |
http://copperalliance.org.uk/uploads/2018/...usbars.pdf |
