Home > Td5 > Correct Front Door Seals TD5
ijefferyes
United Kingdom 2002 Defender 90 2.5 TD CSW Zambezi Silver
Trying to buy a pair of door seals to replace the current tired ones.
When I looking on lrworkshop it directs me to LR024955 and LR077687.
But, these say for 2007 onwards and mine is 2002.
So, will these newer ones fit? If not what is the correct part number?
Post #824911 13th Apr 2020 8:49am
shaggydog
I think they should be fine as long as you mean the big seal which goes all the way around the door.
If its the little one which goes on the bottom of the door they changed when the door pressing changed in around 2006 so best thing to do is go out and look to see if your door bottom has a square welded appearance or a rounded pressed one. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #824923 13th Apr 2020 9:47am
ijefferyes
I mean the long seal that goes all the way around the door frame. Not the one on the bottom of the door.
Post #824924 13th Apr 2020 9:51am
shaggydog
Yep thats them Thumbs Up
Best start in the top corners then just tap it home with a hammer. Also a good idea to check the gaffa tape in the corners behind the old seals where the roof meets the windscreen and B posts as if its missing or loose it may cause leaks. Just put a square of new tape if they look damaged. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #824926 13th Apr 2020 10:04am
ijefferyes
Great, thanks for help!
Post #824927 13th Apr 2020 10:06am
lightning
What is this tape you speak of? There’s none on my TD5. Can someone post a picture of where the tape should go exactly?
Post #824933 13th Apr 2020 10:43am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
If you have the seal off there are some places where there is no metal where the seal is clamped around by head I would look at the top part where the roof connects to the windscreen and where the windscreen comes to the bulkhead.
On the rear side off the door: at the top connection to the roof and where the rearbody and the rear sides come together. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #824985 13th Apr 2020 2:43pm
Mdm
to make it easier take the pin out of the door check strap and tat allows a but more space ,be careful it doesn't hit the door pillar.
we always start at the windscreen corner and do the front 1 first
for the gaps gaffer tape will do fine
Post #824992 13th Apr 2020 3:38pm
bankz5152
Fit the new tdci ones.
Post #825008 13th Apr 2020 5:20pm
theheffman
United Kingdom 2003 Defender 90 Td5 SW Cairns Blue
check out this video for fitting
always buy the genuine LR seals, they are the only ones that really fit
Post #827860 26th Apr 2020 9:25pm
theheffman
Post #827861 26th Apr 2020 9:26pm
