Home > Td5 > Correct Front Door Seals TD5 |
ijefferyes Member Since: 11 Apr 2020 Location: Radstock Posts: 35 |
Trying to buy a pair of door seals to replace the current tired ones.
When I looking on lrworkshop it directs me to LR024955 and LR077687. But, these say for 2007 onwards and mine is 2002. So, will these newer ones fit? If not what is the correct part number? |
13th Apr 2020 8:49am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
I think they should be fine as long as you mean the big seal which goes all the way around the door.
If its the little one which goes on the bottom of the door they changed when the door pressing changed in around 2006 so best thing to do is go out and look to see if your door bottom has a square welded appearance or a rounded pressed one. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
13th Apr 2020 9:47am |
I mean the long seal that goes all the way around the door frame. Not the one on the bottom of the door.
13th Apr 2020 9:51am |
Yep thats them
Best start in the top corners then just tap it home with a hammer. Also a good idea to check the gaffa tape in the corners behind the old seals where the roof meets the windscreen and B posts as if its missing or loose it may cause leaks. Just put a square of new tape if they look damaged. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
13th Apr 2020 10:04am |
Great, thanks for help!
13th Apr 2020 10:06am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
If you have the seal off there are some places where there is no metal where the seal is clamped around by head I would look at the top part where the roof connects to the windscreen and where the windscreen comes to the bulkhead.
On the rear side off the door: at the top connection to the roof and where the rearbody and the rear sides come together. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
13th Apr 2020 2:43pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1534 |
to make it easier take the pin out of the door check strap and tat allows a but more space ,be careful it doesn't hit the door pillar.
we always start at the windscreen corner and do the front 1 first for the gaps gaffer tape will do fine |
13th Apr 2020 3:38pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2077 |
Fit the new tdci ones. Instagram @defender_ventures
Empire Tuning - Agent |
13th Apr 2020 5:20pm |
theheffman Member Since: 21 Mar 2019 Location: bath Posts: 60 |
check out this video for fitting
always buy the genuine LR seals, they are the only ones that really fit |
26th Apr 2020 9:25pm |
26th Apr 2020 9:26pm |
