![]() | Home > Td5 > Seat Belt Replacement Disaster - A Cry for Help |
Can you unbolt and remove the seat, only 4 bolts, dead easy, it might give you more access. Your photo doesn’t really reveal anything tbh QRZ 2e0vpf
rustyredwreck Member Since: 16 Jan 2020 Location: Oxfordshire Posts: 24 ![]() ![]() ![]() |
The photo is just intended to show the metal bracket to which the seat belt "clip" is attached - the parts manual shows a stalk - I have a rectangular rigid bracket instead. I'll see if I can get a better photo.
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1905 ![]() ![]() |
Not sure about your first question - I've tried googling the part number, but all the searches tell me it's been superseded, and won't show me the original!
I 'think' I know what it is, and wonder if you could just take it out of the car; grind/drill out the remains of the broken bolt, and use a nut and bolt as an temporary alternative? On the stalk vs. rigid thing, the stalk is an older fitment. My '94 era Tdi comes with them, the rigid bracket, which has a swivel thing bullt in is newer. Have you tried looking up 'new LR cat' for your era of car - maybe show what you need? (Edit - just had a look - are you after EVL104360?) Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... Last edited by donmacn on 10th Apr 2020 7:11pm. Edited 1 time in total |
More photos
Having just spoken to a random Puma owner in the street my seat belt clip is mounted on something similar to a Puma's. ![]() Click image to enlarge |
Yep - see my post above - try the 'new lr cat' site, a great resource for part numbers, or even for the exploded diagrams showing how things are supposed to come together.
Are you after one of those seatbelt catches/plates? I might have a couple kicking about if I can find them. I bought a whole seatbox once upon a time, which came with them attached. No use to me, on a Tdi. (edit - just found MRC8524 - if your car is a 90, then my advice might not apply but: on a 110 you can get access to the back of this by removing the centre seatbox cover. This makes it a one person job to loosen/tighten the nut and bolt. The rivet - maybe a dremel or a file?? If you can get it out, then as I said above, I'd be tempted, even temporarily, to bolt your seat belt catch onto this bracket, and then bolt/rivet the bracket back into the car. Hope that makes sense.) Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Thanks for the suggested temporary repair Donald - I'll be giving it a go.
I've managed to locate the seat bracket short end (buckle) part number - EVL104360 for the RH side - you were right Donald - thank you.. This part doesn't appear in mu hard copy of the TD5 parts manual - but I've found it under a Puma part. So, next time more looking for the part before I cry out for help! Thanks for the comments - very grateful, Kind Regards Neil |
