Home > Td5 > Pros and cons of spare relocation
Page 2 of 2 <12
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
As mine was a pick-up and now a hardtop with a full rollcage with a cross behing the seats I moved the spare wheel carier from the rear bulkhead to the floor. I use that when I run the 35"Simexes. Normally I use 235 85 bfg and the spare off that goes on the rear door.
On this occasion using the 235 85 on the road and the spare on the door I needed to save space inside. 5 simexes, spare parts, toolbox and all camping gear was little much so from then I use a space saver for my Simexes. I just carry a spare inner tube.
I know at home it only takes me about 15 minutes to change an inner tube so off-road it might take a little longer.
Pro's and conn's for me.
when off-roading I have the space inside it will save the reardoor hindges. For normal use on the rear door I have more space inside. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #824317 9th Apr 2020 6:02pm
CarMan
Tommo, which wheel bracket please and any chance of a pic Question Thumbs Up
Post #824318 9th Apr 2020 6:03pm
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
GREENI wrote:
@widget, that’s a nice 90!
I thought about Widget’s solution in the v8, but I felt it stops the convenience of reaching in the back from the seats etc.
Cheers - and I must return the compliment on your V8 as well Thumbs Up I watch and learn via Instagram and look forward to hearing what the Fox shocks are like.
Agree re reaching back - at first I kept tw@ing my elbow on the tyre, but I soon got used to it. JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #824322 9th Apr 2020 6:20pm
Lodelaner
roel wrote:
... I just carry a spare inner tube.
Interesting - not long ago I had 2 flats on my Disco on the same lane and it wrecked the weekend away. I ended up buying a serviceable set of wheels and tyres on ebay in the middle of Wales!
I would like to know how to do a tube change as a bit of a skill in my back-pocket. I've got a set of tubed Rostyles to replace the Wolfs on my 90. JB
Post #824323 9th Apr 2020 6:26pm
roel
I use my high jack below my sidebar to push the tyre seal to the middle off the rim. And I have 2 crowbars with them Iget one side off the tyre off the rim and then you can change the innertube. Put a little air in so it sits nice and then put the tyre back on the rim with the crowbars. Be carefull not to damage thesealing area off the tyre.
Pump it up till the tyre seats again and relaese some pressure to your liking.
It is easy but it can be a bit off a workout. Roel
Post #824326 9th Apr 2020 6:37pm
Thank you Thumbs Up I’m looking forward to trying the Fox out properly, I’ll share when I can, a trip to the MOT wasn’t enough to tell!
Post #824327 9th Apr 2020 6:39pm
Page 2 of 2 <12
