![]() | Home > Maintenance & Modifications > Vacuum pump oil pipe |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Have a look here:
https://www.lrworkshop.com/diagrams/land-r...ator_53203 Looks like YKL100120 is the bit to me. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
beardiedog Member Since: 01 Aug 2019 Location: Northampton Posts: 27 ![]() ![]() ![]() |
HI It's number 10 in the diagram the other pipe is OK I have ordered a new copper washer but it's the drain pipe I need
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
The critical measurements are the internal diameter and the length.
It is a very simple length of (oil-resistant) rubber hose, and any hose or hydraulic pipe supplier should be able to sort you out. |
The OD of nylon pipe that corners to the pipe your after is 8.84 mm. SQC500010 is 70 mm long prox
thanks OD do you mean outside diameter will than mean the internal will be OK or should I measure that, sorry I'm a bit clueless with this..
I think that dorsetsmith is actually saying that the outside diameter of the pipe that the one you need fits on to is 8.84mm, so the inside diameter of the one you need should fit onto this one, so probably about 8.5mm.
I think..... If in doubt, measure the outlet on the vac pump and the spigot on the engine, these should give you the ID for the pipe you need. |
OK thanks that makes sense thinking about it the outside diameter would be more than that thanks dorsetsmith
