Home > Maintenance & Modifications > Vacuum pump oil pipe
beardiedog
England 2003 Defender 110 Td5 G4 Challenge Tangiers Orange
I removed the alternator at the weekend and made a bit of a mess of the little oil pipe attached to the brake server vacuum pump. The part is apparently obsolete can anybody advise on somewhere I could get a bit of pipe the same size I don't know where or what to measure. The part is apparently SQC500010
Post #823622 6th Apr 2020 9:21am
rallysteve
Have a look here:
https://www.lrworkshop.com/diagrams/land-r...ator_53203
Looks like YKL100120 is the bit to me.
Cheers,
Post #823626 6th Apr 2020 9:36am
beardiedog
HI It's number 10 in the diagram the other pipe is OK I have ordered a new copper washer but it's the drain pipe I need
Post #823629 6th Apr 2020 9:42am
The critical measurements are the internal diameter and the length.
It is a very simple length of (oil-resistant) rubber hose, and any hose or hydraulic pipe supplier should be able to sort you out.
Post #823632 6th Apr 2020 9:48am
dorsetsmith
The OD of nylon pipe that corners to the pipe your after is 8.84 mm. SQC500010 is 70 mm long prox
Post #823639 6th Apr 2020 10:23am
beardiedog
thanks OD do you mean outside diameter will than mean the internal will be OK or should I measure that, sorry I'm a bit clueless with this..
Post #823642 6th Apr 2020 10:30am
I think that dorsetsmith is actually saying that the outside diameter of the pipe that the one you need fits on to is 8.84mm, so the inside diameter of the one you need should fit onto this one, so probably about 8.5mm.
I think.....
If in doubt, measure the outlet on the vac pump and the spigot on the engine, these should give you the ID for the pipe you need.
Post #823663 6th Apr 2020 1:31pm
beardiedog
OK thanks that makes sense thinking about it the outside diameter would be more than that thanks dorsetsmith
Post #823665 6th Apr 2020 1:40pm
