Home > Puma (Tdci) > What is the puma era alternator/starter motor cable size?
Matt110
Seems like a stupid question - just go measure it right?
What I need is the copper inside the cable - cross sectional area/diameter, so i can get the right cable size matched in the other side of a mega fuse i'm installing to replace the awful one that's fitted to the battery terminal as standard. Going in as part of a dual battery install.
Does anyone have access to a wiring diagram that lists cable sizes, a starter motor pulls 1000a at cranking short term, but the cable isn't sized according to that current rating or it would be in excess of 70mm2 cable. It's not. It's closer to 35mm2.
I don't want to cut the cable and reterminate whats already a good termination done by the wiring supplier of JLR at build. And that's the only way to tell on the vehicle without baring out the copper and stripping the insulation - which isn't really desirable either Neutral Neutral
There you are. My lock-in saturday night pondering question! Very Happy Very Happy
Post #823352 4th Apr 2020 8:51pm
jst
35mm2 will do the job. Not sure what std lr is, I would guess at 35. It's not 70mm2. We run 70 and 90mm2 for heavy winch current applications. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #823356 4th Apr 2020 9:02pm
Matt110
Thanks, would certainly be good if it was 35mm2 as that's what i've got in the shed and i'd rather not buy another reel. Not cheap stuff!! The overall diameter looks about 35 ish.
Trouble is you can't just go " well what carries 1000a then as that's peak current " as it's not sized based on continuous load.
My 8274 is on 35mm cable too incidentally. Have you ever had issues with running 35 or just went for 70/90 out of speccing for continuous load? 35's all i had at the time again - could switch it over just wondering if you'd ever run it and seen an issue. It's only got a standard motor on it.
Post #823360 4th Apr 2020 9:08pm
Martin
Site Admin
It’s 40.0mm2 Smile
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #823425 5th Apr 2020 9:50am
diduan
Bulgaria
Interesting, great info! I was planning to mount a battery cut off switch soon and bought 35mm2 cable for the job...now I will have to reconsider my cable choice. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #823438 5th Apr 2020 10:29am
macfrank
Martin wrote:
It’s 40.0mm2 Smile
Hi Martin,
that's interesting. In the 2012 and 2015 wiring diagrams I have, it's 50mm^2.
Post #823444 5th Apr 2020 10:46am
jst
35mm2 will work no problem. I have 4 pumas wired with it.
Ref the 70/90mm2 we used to run competition vehicles. With a std motor bow1 size, 35mm will cope. When we moved to bow 2, then bow3s, then twin motor bow3s the current draw was huge hence bigger cable. Twin bow3s (9hp each) was originally 4 x 1000cca, 110ah batts to cope with demand, that's with two alternates . In end went 24v through 12v so current was reduced, line speed increased and motors saw a good 18 to 22v under load, which is far healthier for them than 9v!
Edited to add we were prototyping for goodwinch for 12 years or so. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #823583 5th Apr 2020 10:42pm
dorsetsmith
Martin wrote:
It’s 40.0mm2 Smile
alternator wire 25.0 mm2 for 2.4 and 2.2
Post #823615 6th Apr 2020 8:52am
Matt110
Thank you all. Really appreciate the help. Love this community!
Where do the wiring diagrams come from, anywhere I can download a full vehicle one from?
Post #823630 6th Apr 2020 9:42am
dorsetsmith
2.4 or 2.2 Question
Post #823631 6th Apr 2020 9:45am
Matt110
2.2 and TD5 if possible? Thumbs Up Thumbs Up
Post #823682 6th Apr 2020 3:31pm
Martin
Site Admin
300 Tdi: 25mm²
Td5: 40mm²
2.4 Puma: 40mm²
2.2 Puma: 50mm²  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #823684 6th Apr 2020 3:38pm
diduan
Bulgaria
I wonder if there was a reason for going from 40mm2 to 50mm2 in 2.2tdci? Defender 110 SW MY2011 2.4tdci decat, no EGR
Post #823692 6th Apr 2020 4:20pm
dorsetsmith
Post #823701 6th Apr 2020 5:00pm
