![]() | Home > Puma (Tdci) > What is the puma era alternator/starter motor cable size? |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8489
35mm2 will do the job. Not sure what std lr is, I would guess at 35. It's not 70mm2. We run 70 and 90mm2 for heavy winch current applications. Cheers
| Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 688
Thanks, would certainly be good if it was 35mm2 as that's what i've got in the shed and i'd rather not buy another reel. Not cheap stuff!! The overall diameter looks about 35 ish.
Trouble is you can't just go " well what carries 1000a then as that's peak current " as it's not sized based on continuous load. My 8274 is on 35mm cable too incidentally. Have you ever had issues with running 35 or just went for 70/90 out of speccing for continuous load? 35's all i had at the time again - could switch it over just wondering if you'd ever run it and seen an issue. It's only got a standard motor on it. Click image to enlarge |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6732
It’s 40.0mm2
Click image to enlarge 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260
Interesting, great info! I was planning to mount a battery cut off switch soon and bought 35mm2 cable for the job...now I will have to reconsider my cable choice. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138
Hi Martin, that's interesting. In the 2012 and 2015 wiring diagrams I have, it's 50mm^2. ![]() |
35mm2 will work no problem. I have 4 pumas wired with it.
Ref the 70/90mm2 we used to run competition vehicles. With a std motor bow1 size, 35mm will cope. When we moved to bow 2, then bow3s, then twin motor bow3s the current draw was huge hence bigger cable. Twin bow3s (9hp each) was originally 4 x 1000cca, 110ah batts to cope with demand, that's with two alternates . In end went 24v through 12v so current was reduced, line speed increased and motors saw a good 18 to 22v under load, which is far healthier for them than 9v! Edited to add we were prototyping for goodwinch for 12 years or so. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
alternator wire 25.0 mm2 for 2.4 and 2.2 |
Thank you all. Really appreciate the help. Love this community!
Where do the wiring diagrams come from, anywhere I can download a full vehicle one from? |
2.4 or 2.2
2.2 and TD5 if possible?
300 Tdi: 25mm²
Td5: 40mm² 2.4 Puma: 40mm² 2.2 Puma: 50mm² 1988 90 Td5 NAS soft top
2015 D90 XS SW |
I wonder if there was a reason for going from 40mm2 to 50mm2 in 2.2tdci? Defender 110 SW MY2011 2.4tdci decat, no EGR
2.2 LHD https://1drv.ms/b/s!AtZSoWFHDgnGlB8iSFfsA9JN_EFj?e=382XRD TD5 2002 https://1drv.ms/b/s!AtZSoWFHDgnGlGJ6dB05NJC8QFj9?e=gLisej amendments TD5 see below https://1drv.ms/b/s!AtZSoWFHDgnGlGMObrLrqqEgHyTs?e=OHjVRl thanks tio martin |
| All times are GMT |
