![]() | Home > Maintenance & Modifications > td5 and td4 fuel tanks |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17916 ![]() ![]() ![]() |
Assuming that by Td4 you mean TDCi, then I think that they are. The Puma tank pickup is the same as a TD5 pickup/pump except without the pump - the plastic body even has the mouldings where the pump would be on a TD5 unit.
I replaced the one on my '07 110 some time ago and came to the conclusion that somewhere in Solihull there's a bloke who takes TD5 units and strips the pump out to turn them into TDCi units, it was the only explanation I could find for the TD5 (with pump) being cheaper than the TDCi (without pump)! As far as I know the tank itself is identical, certainly on an early Puma. |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 679 ![]() ![]() ![]() |
Tanks are interchangeable.
The breather setup changed during Puma years - some had two breather lines, others had one breather with the second t’eed off the main breather. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8377 ![]() ![]() ![]() |
td5 = tdci, yes
thank you guys, much appreciated Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Sounds like the TDCi pickup unit is the same as a late 300Tdi RoW fuel tank (was rear mounted like Td5's, well in 90's anyway)
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6699 ![]() ![]() ![]() |
Certainly is
That's useful to know, I wonder if the 300Tdi unit is the same outrageous price as the Puma one. Probably.
