Home > Maintenance & Modifications > td5 and td4 fuel tanks
jst
does anyone know if they are interchangable?
i know the pump setup is different on each but are the tanks and fittings universal? ie could you drop a td4 tank and fit the ancils to a td5 tank? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #821521 26th Mar 2020 10:28pm
Assuming that by Td4 you mean TDCi, then I think that they are. The Puma tank pickup is the same as a TD5 pickup/pump except without the pump - the plastic body even has the mouldings where the pump would be on a TD5 unit.
I replaced the one on my '07 110 some time ago and came to the conclusion that somewhere in Solihull there's a bloke who takes TD5 units and strips the pump out to turn them into TDCi units, it was the only explanation I could find for the TD5 (with pump) being cheaper than the TDCi (without pump)!
As far as I know the tank itself is identical, certainly on an early Puma.
Post #821523 26th Mar 2020 10:50pm
Oldowner
Tanks are interchangeable.
The breather setup changed during Puma years - some had two breather lines, others had one breather with the second t’eed off the main breather.
Post #821531 26th Mar 2020 11:43pm
jst
td5 = tdci, yes
thank you guys, much appreciated Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #821548 27th Mar 2020 8:22am
Sounds like the TDCi pickup unit is the same as a late 300Tdi RoW fuel tank (was rear mounted like Td5's, well in 90's anyway)
Post #821596 27th Mar 2020 10:58am
Martin
Site Admin
Certainly is Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #821614 27th Mar 2020 11:34am
That's useful to know, I wonder if the 300Tdi unit is the same outrageous price as the Puma one. Probably.
Post #821620 27th Mar 2020 11:59am
