Home > Td5 > Misfiring on start up
stigomery
United Kingdom 2004 Defender 90 Td5 HT Belize Green
Morning all...
So the TD5 has started misfiring on start up.
I replaced the wiring harness last year and check/clean it about every 2-3 months but TBH there hasn't been any oil in the red socket for quite a while now.
My suspicion lies with the injector seals since the problem goes away after 10-15 minutes, i.e. when the engine has reached temperature.
I have access to a Hawkeye but TBH I don't know what I'm looking for, cylinder roughness is about 2-5% when running but can rise to around +/- 18% when rough.
What's the best diagnosis process?
Is this an easy to do job myself or garage? Do I need special tools to remove the injectors?
Anything I should be careful of?
Thanks,
Post #819954 17th Mar 2020 10:25am
Mdm
workshop job ideally.
not too bad a job to do once you have done once or watched a workshop do it
Post #819964 17th Mar 2020 11:16am
dorsetsmith
see below this will give head up on td5 injector seal
http://www.discovery2.co.uk/Injector%20Seals.html
Post #819974 17th Mar 2020 1:19pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Hi,
Are you getting any mixing of diesel in the oil?
Those numbers for injector balance are a long way out- I believe that +/- 3-5 is good/normal.\
Regards
Chris
Post #820095 18th Mar 2020 1:37pm
