Home > Td5 > Defender hazard lights constantly Running...
Davey Jones
New Zealand 2004 Defender 110 Td5 XS CSW Bronze Green
So it goes like this.. out climbing an ugly bank out of the Waipara river and giving it the beans and the stereo fell out of the dash. At this point the hazard lights came on and stayed on. I got back to camp and pulled.the hazard light switch out the hazard and indicator fuse out and no change pulled the flasher unit. No change. Disconnected the battery and gave it 10 min then reconnected it, it pulsed the door locks and kept flashing. Took the drivers seat and pulled the central locking fuse out and it turned them off. A we bit of moisture but nothing obscene in the compartment and all components were dry. Left the fuse out and headed home late that afternoon put the fuse in at home and no central locking and all indicators still flashing.
Any ideas would be greatly appreciated.
Post #818749 8th Mar 2020 9:48am
4RF RDS
Go behind the dash and have a look at the 10AS unit. Possibly messed with the plug?? Is sounds like the alarm is active? Try resetting the immobilizer with the fob first.
Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #818774 8th Mar 2020 12:49pm
Davey Jones
So the 10as unit is the wee green box tucked right in behind the dash? The remote fob seems to do nothing and yes that's with the fuse in I will unplug it tonight and have a play.
Post #818827 8th Mar 2020 8:10pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Reset the rollover inertia switch?
In the event of an accident it'll open the door locks and set the hazards off. If anything it's worth a look. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #818932 9th Mar 2020 6:55pm
Davey Jones
So it was missing a screw in the 10as unit ... so I unplugged it re secured it and plugged it back in and all sorted. It took a while to recognise the key again.
Thanks all for the advice Very Happy
Post #819380 13th Mar 2020 5:20am
4RF RDS
Thanks for updating the solution. Its how we all share and learn. I knew it must have been the 10AS Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #819654 14th Mar 2020 9:27pm
