![]() | Home > Td5 > Defender hazard lights constantly Running... |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 980 ![]() ![]() ![]() |
Go behind the dash and have a look at the 10AS unit. Possibly messed with the plug?? Is sounds like the alarm is active? Try resetting the immobilizer with the fob first.
Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Davey Jones Member Since: 08 Mar 2020 Location: Canterbury Posts: 3 ![]() ![]() ![]() |
So the 10as unit is the wee green box tucked right in behind the dash? The remote fob seems to do nothing and yes that's with the fuse in I will unplug it tonight and have a play.
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
Reset the rollover inertia switch?
In the event of an accident it'll open the door locks and set the hazards off. If anything it's worth a look. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
So it was missing a screw in the 10as unit ... so I unplugged it re secured it and plugged it back in and all sorted. It took a while to recognise the key again.
Thanks all for the advice ![]() |
Thanks for updating the solution. Its how we all share and learn. I knew it must have been the 10AS
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
