Home > Puma (Tdci) > A Frame Soft Bar Help - SVX Front |
Good morning,
I have a genuine non winch compatible soft A-bar installed on the SVX from new. Checked dealer invoice and part number is Defender LR005235. The same soft A-bar but winch compatible at that time (late 2008) was LR005742. These versions have the word Defender embedded in the top horizontal bar. (copies often don't) Not sure if the VPLPP0060 (non winch) and VPLPP0061 (winch) numbers have superseded the above two numbers, or if it is the other way around. Hope helps. Eric Click image to enlarge Click image to enlarge Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
8th Feb 2020 7:21am |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 |
Click image to enlarge This is mine when i had the A frame on and svx grill/lights, its avaliable if your interested? Also hs spot light brackets attatched wth the lights avaliable too. |
8th Feb 2020 6:41pm |
