Home > Puma (Tdci) > A Frame Soft Bar Help - SVX Front
darwin1
Hello Members.
I have a 2015 110 Wagon and installed the genuine SVX front fascia (grill, lights).
I am looking to install a genuine A-frame bar, but not sure If it is SVX grill compatible? If so, what model fits, winch or non-winch version?
Any help or pics would be much appreciated.
Post #814128 8th Feb 2020 3:11am
ericvv
Good morning,
I have a genuine non winch compatible soft A-bar installed on the SVX from new. Checked dealer invoice and part number is Defender LR005235. The same soft A-bar but winch compatible at that time (late 2008) was LR005742. These versions have the word Defender embedded in the top horizontal bar. (copies often don't)
Not sure if the VPLPP0060 (non winch) and VPLPP0061 (winch) numbers have superseded the above two numbers, or if it is the other way around.
Hope helps.
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #814131 8th Feb 2020 7:21am
Adammacky
This is mine when i had the A frame on and svx grill/lights, its avaliable if your interested? Also hs spot light brackets attatched wth the lights avaliable too.
Post #814202 8th Feb 2020 6:41pm
