Home > Off Topic > Tube notching inserts....
excossack
What I am after is some tube notching inserts I can put in the end of say a 15mm tube to meet up to another 15mm tube to give the impression of being notched. Does that make sense?
Basically what I am after is to effectively create a T piece with tube and attach them together with say glue or other bonding agent. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #813567 4th Feb 2020 4:56pm
X4SKP
Hello excossack
Do you have your tube? is so...
What material is your tube?
What is the internal and external diameter of your tube?
What is the T piece being used for?
If you don't have your tube...
What is the T piece being used for? SKIP
Post #813570 4th Feb 2020 5:07pm
excossack
Hi
What material is your tube - mild steel I think
What is the internal and external diameter of your tube? - 15mm ID
What is the T piece being used for? - to create a lightweight frame for a project- the idea being, drill through the middle and insert a bolt, drill through the tube forming the T and terminate or add another T
Its not me building its a mate so researching ideas. 1999 Defender TD5 110
Regards
John M0VAZ
Post #813572 4th Feb 2020 5:13pm
X4SKP
Give these guys a call...
https://www.carbuilder.com/uk/tees#/pageSi...;orderBy=0
They have more than on their site. SKIP
Post #813579 4th Feb 2020 5:32pm
excossack
Cheers, its not quite what I had in mind. I was thinking more along on the lines of an end cap with a notch cut out so this would butt up to another pipe rather than a full on T piece 1999 Defender TD5 110
Regards
John M0VAZ
Post #813590 4th Feb 2020 6:31pm
ickle
15mm holesaw in a pillar drill and braze it together after.....
15mm copper T glue and fill?
I’ve seen some plastic joints like you describe on garden furniture, the bolt though the side of the tube expands the plastic plug in the end of the other, where you’d buy them though? EBAY?
Keith
Post #813637 4th Feb 2020 8:37pm
excossack
I've seen them as well. It trying to find out the proper name. 1999 Defender TD5 110
Regards
John M0VAZ
Post #813701 5th Feb 2020 9:05am
MartinK
More like this? https://www.ebay.co.uk/itm/Plastic-Garden-..._03DTuVeXw Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #813705 5th Feb 2020 9:33am
Is kee clamp too industrial for you ~ I've used it a few times for frames and the like and works pretty well.
Post #813758 5th Feb 2020 5:05pm
excossack
Too industrial. Those plastic inserts from chairs would do the job. 1999 Defender TD5 110
Regards
John M0VAZ
Post #813759 5th Feb 2020 5:14pm
