Home > In Car Electronics > Door speaker sound insulation
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
I am upgrading the door speakers and will insulate the inner door skin and door card.
I was wondering about the outer door skin whether just Dynamat/Silent Coat is necessary or should I add a layer of dense closed foam like dodo
Thanks
Post #812981 31st Jan 2020 11:17pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
The outer skin has a patch of panel dense material ( like dynamat ) already on it so adding more won't do much.
A closed cell foam will be helpful although probably not a huge amount.
You will need to strip the window and gubbins out to get to fix to the outer panel succesfully as there is alot going on in the door.
Post #813254 2nd Feb 2020 6:23pm
bm52
Thanks for the advice
Post #813257 2nd Feb 2020 6:27pm
