![]() | Home > Puma (Tdci) > 2.4 Puma 90 Blower not working |
![]() Click image to enlarge none a/c wiring diagram The resistor accessible can be removed from the side of blower motor fan plastic housing ![]() Click image to enlarge |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
I’ve done exactly this today and it seem to have cured the problem 👍 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
SDarks Member Since: 28 Jan 2020 Location: Sussex Posts: 3 ![]() ![]() ![]() |
Thanks for the quick and informative responses, will update at the weekend if fixed/not fixed.
Cheers! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
The drawing shows the LHD heater box, on RHD it's on the same side of the box, but the box is obviously on the other side ![]() ![]() ![]() |
*Update*
Replaced the resistor today, fiddly job but it was okay. Unfortunately it did not solve my problem ![]() Interestingly the fans blow when A/C is on but no adjustment in the speed. When a\c is off no blow. Any suggestions on next port of call before I take it in ? Thanks, |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17940 ![]() ![]() ![]() |
It is not unknown for the bulbs that illuminate the heater controls to melt the fan switch in the control panel, causing this sort of effect. Unfortunately the heater control panel is available only as an assembly and is shockingly expensive.
Generally if this has happened the slider won't slide smoothly. If yours does still move smoothly it probably isn't this problem. |
a/c wiring diagram
![]() Click image to enlarge ![]() Click image to enlarge |
MMR1988 Member Since: 29 Oct 2016 Location: Chemnitz Posts: 54 ![]() ![]() ![]() |
As the blower is working when A/C is switched on, there is only one thing that can cause the problem - the switch itself. Maybe the connector of the switch is not connected the right way?
