Home > Puma (Tdci) > 2.4 Puma 90 Blower not working
SDarks
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi All,
I am new to this forum and 6 months into ownership of my first Defender, a 2.4 90 XS station wagon and everything has been peachy so far. Looking for some advise on a problem that has come up.
Yesterday the blower started to cut out intermitnatly unless it was on full speed setting. After another 15 miles down the road the blower stoped working on all settings.
As soon as I got home a quick google suggested that it could be the heater resistor, ordered one for £25 which comes tomorrow.
First question - Before I start taking bits apart in true amateur spannering style on the driveway, is the resistor accessible to plug and unplug and where is the location ?
Second question - If I fail to fix it with the resistor replacement can anyone recommend a good Indie in the West Sussex area?
Thanks in advance.
Post #812292 28th Jan 2020 10:45am
dorsetsmith
none a/c wiring diagram
The resistor accessible can be removed from the side of blower motor fan plastic housing
Post #812299 28th Jan 2020 12:02pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I’ve done exactly this today and it seem to have cured the problem 👍 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #812365 28th Jan 2020 9:09pm
SDarks
Thanks for the quick and informative responses, will update at the weekend if fixed/not fixed.
Cheers!
Post #812442 29th Jan 2020 10:21am
Martin
Site Admin
dorsetsmith wrote:
The drawing shows the LHD heater box, on RHD it's on the same side of the box, but the box is obviously on the other side Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #812458 29th Jan 2020 11:50am
dorsetsmith
^ Thumbs Up you beet me to it
Post #812465 29th Jan 2020 12:37pm
SDarks
*Update*
Replaced the resistor today, fiddly job but it was okay. Unfortunately it did not solve my problem Sad
Interestingly the fans blow when A/C is on but no adjustment in the speed. When a\c is off no blow.
Any suggestions on next port of call before I take it in ?
Thanks,
Post #813064 1st Feb 2020 2:28pm
It is not unknown for the bulbs that illuminate the heater controls to melt the fan switch in the control panel, causing this sort of effect. Unfortunately the heater control panel is available only as an assembly and is shockingly expensive.
Generally if this has happened the slider won't slide smoothly. If yours does still move smoothly it probably isn't this problem.
Post #813071 1st Feb 2020 2:45pm
dorsetsmith
a/c wiring diagram
Post #813072 1st Feb 2020 2:51pm
MMR1988
Germany 2008 Defender 110 Puma 2.4 SW Alaska White
As the blower is working when A/C is switched on, there is only one thing that can cause the problem - the switch itself. Maybe the connector of the switch is not connected the right way?
Post #813083 1st Feb 2020 3:29pm
