Home > Maintenance & Modifications > help! I am not able to take the pin from a connector |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2108 |
Hi there!
I have a broken cable in aconnector but Im not able to take out the pin. I already open the lid in the back and try to use a small allen and a clip to release the pin but nothing. Any special trick to do it? Thanks! Click image to enlarge Click image to enlarge Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
26th Jan 2020 3:21pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6475 |
Small flat blade screwdriver, in through the front of the connector (non wire side) in the non-square hole. You need to lever a small plastic latch away from the metal terminal, then gently pull the wire to free it. If no wire attached (like here) use something thin to push the terminal out backwards. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
26th Jan 2020 3:48pm |
Thanks Martin
I thnnk I need a smaller screwdriver that the one that I using to release the latch... Not funny work. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
26th Jan 2020 4:44pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
I got one of these kits from ebay - not this exact one as I got mine ages ago and cannot remember the seller
https://www.ebay.co.uk/itm/18Pcs-Car-Wire-...SwdHpb6m~p Haven't needed to use one since I got the kit |
27th Jan 2020 8:55pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 485 |
A safety pin works well to lift the retaining tang. This animated cross-section shows what you need to do - . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
27th Jan 2020 10:57pm |
