Home > Maintenance & Modifications > help! I am not able to take the pin from a connector
Eduardo
Hi there!
I have a broken cable in aconnector but Im not able to take out the pin.
I already open the lid in the back and try to use a small allen and a clip to release the pin but nothing.
Any special trick to do it?
Thanks!
 Eduardo
Post #812053 26th Jan 2020 3:21pm
Martin
Site Admin
Small flat blade screwdriver, in through the front of the connector (non wire side) in the non-square hole. You need to lever a small plastic latch away from the metal terminal, then gently pull the wire to free it. If no wire attached (like here) use something thin to push the terminal out backwards.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #812058 26th Jan 2020 3:48pm
Eduardo
Thanks Martin
I thnnk I need a smaller screwdriver that the one that I using to release the latch...
Not funny work.
Cheers Eduardo
Post #812063 26th Jan 2020 4:44pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I have better experience with a needle to loosen the clip inside the plastic body. Even watchmaker screwdrivers are sometimes too large. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #812125 27th Jan 2020 7:58am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
I got one of these kits from ebay - not this exact one as I got mine ages ago and cannot remember the seller
https://www.ebay.co.uk/itm/18Pcs-Car-Wire-...SwdHpb6m~p
Haven't needed to use one since I got the kit Mr. Green
Post #812218 27th Jan 2020 8:55pm
PaulMc
A safety pin works well to lift the retaining tang.
This animated cross-section shows what you need to do -
. Paul.
Post #812247 27th Jan 2020 10:57pm
