Home > Puma (Tdci) > Clutch replacement
Dexterdog
Clutch replacement
Hi Chaps,
Looking for some advice please.
About to change the clutch, pressure plate and bearing for an LOF clutch kit on my 2.4 tdci.
Is there anything else that should be changed while the box is out ? I have been told to change the concentric slave cylinder unit. Are the flywheels prone to problems ?
Any suggestions gratefully received.
Post #811514 22nd Jan 2020 8:12pm
LR90XS2011
gearbox to transfer box adaptor shaft, or at least check it and grease it DEFENDER 90 TDCI XS,
Post #811516 22nd Jan 2020 8:15pm
Dexterdog
Thumbs Up
Post #811521 22nd Jan 2020 8:24pm
MMR1988
Germany 2008 Defender 110 Puma 2.4 SW Alaska White
Well, this depends if the transfer box is removed separately. If so, then you're right.
You should change at least the Clutch, the slave cylinder and while changing the slave cylinder you maybe need to change it's connectors as there was a change by the supplier and the old slave cylinder isn't longer produced. Flywheel isn't a problem with this engine as long there was no spring from the clutch was fallen between the flywheel and the clutch.
Regards,
Max
Post #811536 22nd Jan 2020 9:57pm
Dexterdog
Thanks Max, really useful
Post #811540 22nd Jan 2020 10:20pm
Remove the t-box separately in order to check the shaft coupling, it's madness not to on a Puma.
Post #811604 23rd Jan 2020 11:58am
Dexterdog
Thanks for the help
Post #811606 23rd Jan 2020 12:00pm
