![]() | Home > Puma (Tdci) > Clutch replacement |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
gearbox to transfer box adaptor shaft, or at least check it and grease it DEFENDER 90 TDCI XS,
Dexterdog Member Since: 23 Jun 2018 Location: gloucestershire Posts: 108 ![]() |
MMR1988 Member Since: 29 Oct 2016 Location: Chemnitz Posts: 54 ![]() ![]() ![]() |
Well, this depends if the transfer box is removed separately. If so, then you're right. You should change at least the Clutch, the slave cylinder and while changing the slave cylinder you maybe need to change it's connectors as there was a change by the supplier and the old slave cylinder isn't longer produced. Flywheel isn't a problem with this engine as long there was no spring from the clutch was fallen between the flywheel and the clutch. Regards, Max |
Thanks Max, really useful
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17940 ![]() ![]() ![]() |
Remove the t-box separately in order to check the shaft coupling, it's madness not to on a Puma.
Thanks for the help
