![]() | Home > Tdi > Turbo health check |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 850 ![]() ![]() |
Pull the pipe off and check the condition of the turbo. A little bit of side to side movement is ok. If you can pull it in and out it won’t be long before you need a new turbo. Standard boost pressure is about 1 bar or just over 14psi if I remember correctly
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 ![]() ![]() ![]() |
My original Turbo [ 25 years old ] is on 370,000 miles [ 595,000 Km] , oil changes are king,,
