Home > Td5 > What type rear diff do I have?
reabros
United Kingdom 2006 Defender 90 Td5 HT Cairns Blue
My 2006 defender 90 has slight play in rear diff which makes an unwanted clunk sometimes so looking to rebuild/replace but not sure what type of diff I have? Any help appreciated! Thanks
Post #810124 13th Jan 2020 8:59pm
landy andy
That will be a “Rover” diff
How much play do you have?
The play can come from diff, shafts, and drive flanges.
Post #810130 13th Jan 2020 9:15pm
jst
diffs usually whine not clonk. sure it's not the drive members or a Bush. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #810135 13th Jan 2020 9:32pm
bankz5152
Take a pic. Likely a long nose
Post #810139 13th Jan 2020 9:58pm
4RF RDS
Rear end clunk is usually the wheel flanges being worn. The diff does not typically clunk, hums, whines, whirrs not clunk. 90s use Rover diffs unless it been modified.
Anyway, good luck Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #810208 14th Jan 2020 3:01pm
rallysteve
A-Frame balljoint is also a common candidate for clunking when pulling away/changing gear.
Post #810213 14th Jan 2020 3:30pm
reabros
Thanks for the replies. Originally I did think it was the A-frame ball joint and then had a friend think that was the clunk when pulling away/changing gear however I took it to a defender specialist near me and they said the A-frame ball joint was fine and it was the rear diff that had play making the clunking noise? Had new rear half shafts put it by them at the same time as they were fairly worn and flanges were ok so I am ruling that out I think. But not really sure what to think now!
Post #810241 14th Jan 2020 7:49pm
jst
Sorry the shafts were worn but the flanges were ok? both original? never heard it being that way around.
In my experience, i know repeting myself, but diffs dont clonk.
when do you get the noise? pulling away, change direction (fwd to rev) on initial takeup?x coasting, under load? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #810309 15th Jan 2020 8:49am
excossack
Could you get a 'clunk' from the diff end if the splines are worn on the diff end where the shafts sit? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #810316 15th Jan 2020 9:42am
The diff end splines are properly lubricated and don't tend to wear significantly.
Post #810328 15th Jan 2020 10:20am
excossack
Cheers, so the only real wear would be the splines then. 1999 Defender TD5 110
Regards
John M0VAZ
Post #810329 15th Jan 2020 10:21am
reabros
Never get it while coasting. Think it's normally if I put my foot down pulling away quickly and its avoidable if I'm being careful. Fairly certain its coming from rear end somewhere, Im thinking it must be the A-frame (even though was told otherwise by a specialist garage) if the diffs definitely don't make a clonk!
Post #810342 15th Jan 2020 12:24pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
If you are looking for play in the driveline, you will find it is probably not play at one point. It will be play in all between all the different parts.
What I would do in your case. Park the car and choke the front wheels. Put the gear box and transfer box in neutral.
Turn the dive shaft to both sides near the diff and see if you have a lot off play. Do the same with the drive shaft to the front axle. If it is about the same it is general wear. If the rear has a lot more play you might have to look at it. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #810394 15th Jan 2020 4:59pm
